Aller au contenu principal
Dell XPS M1730 Webcam Replacement
Ce dont vous avez besoin
  1. Dell XPS M1730 Webcam Replacement, Battery: étape 1, image 1 de 1
    • Push the sliding button near the battery compartment.
  2. Dell XPS M1730 Webcam Replacement: étape 2, image 1 de 1
    • Slide the button next to the battery and lift up on the lip of the battery edge.
  3. Dell XPS M1730 Webcam Replacement: étape 3, image 1 de 2 Dell XPS M1730 Webcam Replacement: étape 3, image 2 de 2
    • Lift and remove the battery.
  4. Dell XPS M1730 Webcam Replacement, Keyboard: étape 4, image 1 de 3 Dell XPS M1730 Webcam Replacement, Keyboard: étape 4, image 2 de 3 Dell XPS M1730 Webcam Replacement, Keyboard: étape 4, image 3 de 3
    • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
  5. Dell XPS M1730 Webcam Replacement: étape 5, image 1 de 2 Dell XPS M1730 Webcam Replacement: étape 5, image 2 de 2
    • Remove the four screws from the top of the keyboard bracket.
  6. Dell XPS M1730 Webcam Replacement: étape 6, image 1 de 3 Dell XPS M1730 Webcam Replacement: étape 6, image 2 de 3 Dell XPS M1730 Webcam Replacement: étape 6, image 3 de 3
    • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
  7. Dell XPS M1730 Webcam Replacement: étape 7, image 1 de 3 Dell XPS M1730 Webcam Replacement: étape 7, image 2 de 3 Dell XPS M1730 Webcam Replacement: étape 7, image 3 de 3
    • Lift the keyboard about 2 inches up from the laptop platform.
    • From this angle the keyboard ribbon connector can be seen and disconnected.
  8. Dell XPS M1730 Webcam Replacement, LCD Screen Display: étape 8, image 1 de 1
    • Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
  9. Dell XPS M1730 Webcam Replacement: étape 9, image 1 de 3 Dell XPS M1730 Webcam Replacement: étape 9, image 2 de 3 Dell XPS M1730 Webcam Replacement: étape 9, image 3 de 3
    • Use iFixit plastic tool and a cutout of cardboard to pry out the plastic bezel around the edges of the LCD screen
  10. Dell XPS M1730 Webcam Replacement: étape 10, image 1 de 3 Dell XPS M1730 Webcam Replacement: étape 10, image 2 de 3 Dell XPS M1730 Webcam Replacement: étape 10, image 3 de 3
    • Disconnect the display connectors by removing them from the grooves and unplugging them.
  11. Dell XPS M1730 Webcam Replacement: étape 11, image 1 de 3 Dell XPS M1730 Webcam Replacement: étape 11, image 2 de 3 Dell XPS M1730 Webcam Replacement: étape 11, image 3 de 3
    • Remove 12 M2x3mm screws along the edge of the screen frame with a PH0 screwdriver.
  12. Dell XPS M1730 Webcam Replacement: étape 12, image 1 de 2 Dell XPS M1730 Webcam Replacement: étape 12, image 2 de 2
    • Disconnect the display connector behind the top of the screen.
  13. Dell XPS M1730 Webcam Replacement, Webcam: étape 13, image 1 de 1
    • Remove the four screws (M2x3mm) surrounding the webcam
  14. Dell XPS M1730 Webcam Replacement: étape 14, image 1 de 1
    • Lift up on the webcam bar to pull it out.
  15. Dell XPS M1730 Webcam Replacement: étape 15, image 1 de 1
    • Remove webcam bar and the metal tray underneath.
    • Your webcam is now removed.
Natalie King
Membre depuis le 02/08/18
156 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 365
