Aller au contenu principal
Dell inspiron 15 5502 Memory modules Replacement
Ce dont vous avez besoin
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
  1. Dell inspiron 15 5502 Memory modules Replacement, Screws: étape 2, image 1 de 1
    • In the back there are 9 screws.
    • (captive) M2x7.5
    • M2x4
    • Unscrew these and store in a safe place. (eg: nescafe cup, container )
  2. Dell inspiron 15 5502 Memory modules Replacement, Getting the base cover out: étape 3, image 1 de 1
    • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: étape 5, image 1 de 2 Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: étape 5, image 2 de 2
    • The sticker and the cable connector(below the sticker)
    • Peel the tape and disconnect the battery cable from the system board.
  4. Dell inspiron 15 5502 Memory modules Replacement, Drain the power: étape 6, image 1 de 1
    • Press and hold the power button for five seconds to ground the computer and drain the flea power.
  5. Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: étape 7, image 1 de 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: étape 7, image 2 de 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: étape 7, image 3 de 3
    • Where I am talking about.
    • Lift the mylar to uncover the memory module.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  6. Dell inspiron 15 5502 Memory modules Replacement, Removing: étape 8, image 1 de 1
    • Remove the memory module from the memory-module slot.
    • Store the Ram sticks safely in an anti-static bag.
Ligne d'arrivée
Kind-hearted, spirited Man
Membre depuis le 08/15/21
1 052 Réputation
4 tutoriels rédigés
Équipe
Android Alliance Membre de l'équipe Android Alliance
Community
91 membres
727 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 579
