Aller au contenu principal
Introduction
Ever want to disassemble and reassemble your Delphi MyFi XM2GO portable XM radio? Follow this guide to learn how to remove the motherboard (PCB logic board) of the Delphi MyFi XM2GO portable XM radio. You will need a Torx T6 screwdriver to complete this guide. Warning: you may have to use your fingernails to pry off certain parts.
Pièces
Aucune pièce spécifiée.
  1. Locate the large button on the top of the device. Push down on the button and slide the cover away from the button. The battery removal tab may pop up.
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Grab the red pull tab and pull down to unlock the latch. Pull the battery out. Pull the battery out.
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Remove the four screws from the bottom of the device using a T6 Torx screwdriver. Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
    • Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
  4. Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail. Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail. Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
    • Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
  5. Remove the two screws under the button using the T6 Torx screwdriver. Remove the two screws under the button using the T6 Torx screwdriver. Remove the two screws under the button using the T6 Torx screwdriver.
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Remove the back cover. Remove the back cover.
    • Remove the back cover.
  7. Remove the power button by pulling it to the left. Remove the power button by pulling it to the left.
    • Remove the power button by pulling it to the left.
  8. Remove the plastic antenna extension connector on the right side of the device. Remove the plastic antenna extension connector on the right side of the device.
    • Remove the plastic antenna extension connector on the right side of the device.
  9. Pull up on the motherboard to remove it from the device. The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed. The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
    • Pull up on the motherboard to remove it from the device.
    • The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
Scott Byer
Membre depuis le 09/03/2012
61 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-2, Benson Spring 2012 Membre de l'équipe Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 2,355
