Aller au contenu principal
DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
Ce dont vous avez besoin
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: étape 1, image 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: étape 1, image 2 de 2
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 2, image 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 2, image 2 de 2
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 3, image 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 3, image 2 de 2
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 4, image 1 de 1
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 5, image 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 5, image 2 de 2
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 6, image 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 6, image 2 de 2
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 7, image 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 7, image 2 de 2
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 8, image 1 de 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 8, image 2 de 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: étape 8, image 3 de 3
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
Ligne d'arrivée
Theodore Tan
Membre depuis le 02/24/15
137 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 23-4, Green Winter 2015 Membre de l'équipe Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 542
