Aller au contenu principal
Desktop PC RAM Replacement
Ce dont vous avez besoin
  1. Desktop PC RAM Replacement, Left Panel: étape 1, image 1 de 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC RAM Replacement: étape 2, image 1 de 2 Desktop PC RAM Replacement: étape 2, image 2 de 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: étape 3, image 1 de 1
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: étape 4, image 1 de 1
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
52 autres ont terminé cette réparation.
David Lennon
Membre depuis le 04/14/15
9 944 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 4-5, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 membres
45 tutoriels rédigés
4 commentaires
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Réponse
very interesting
maciekErd123 - Réponse
how to determine the speed
benzy aceware - Réponse
how can i differentiate between types of rams
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 7,046
