Aller au contenu principal
Motorola RFS4000 Disassembly
  1. Motorola RFS4000 Disassembly, Removing the screw: étape 1, image 1 de 3 Motorola RFS4000 Disassembly, Removing the screw: étape 1, image 2 de 3 Motorola RFS4000 Disassembly, Removing the screw: étape 1, image 3 de 3
    • Screw
    • Torx T8
    • If you don't have a Torx T8 screwdriver you can use a slotted screwdriver
  2. Motorola RFS4000 Disassembly, Opening the chassis: étape 2, image 1 de 2 Motorola RFS4000 Disassembly, Opening the chassis: étape 2, image 2 de 2
    • Slide up the cover
    • Fan cable
    • Before unscrew you must disconnect the fan cable.
  3. Motorola RFS4000 Disassembly, Removing the fan: étape 3, image 1 de 3 Motorola RFS4000 Disassembly, Removing the fan: étape 3, image 2 de 3 Motorola RFS4000 Disassembly, Removing the fan: étape 3, image 3 de 3
    • Fan chassis screws
    • Fan screws
    • Reset Button
    • Power Inlet
  4. Motorola RFS4000 Disassembly, Removing the motherboard: étape 4, image 1 de 3 Motorola RFS4000 Disassembly, Removing the motherboard: étape 4, image 2 de 3 Motorola RFS4000 Disassembly, Removing the motherboard: étape 4, image 3 de 3
    • Motherboard screws
    • RJ45 ports
    • Console port (rj45) and usb port
    • Express card
    • SFP port (Motorola part number: Fiber-3000-1S-WWR)
    • Reset button
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
Eneider Colina
Membre depuis le 09/20/13
2 370 Réputation
9 tutoriels rédigés
Équipe
Comunidad para traductores de español Membre de l'équipe Comunidad para traductores de español
Community
24 membres
249 tutoriels rédigés
Un commentaire
No, it's better not to use a slotted screwdriver, because the screws are tightened quite tight (if they haven't already been unscrewed) and you destroy the screws with them. Time required 30 minutes :-))? 10-15 maybe
omanoman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 273
