Aller au contenu principal
Desoldering Technique
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Desoldering Technique, Desoldering Technique: étape 1, image 1 de 1
    • Gather your solder gun and soldering paste. The soldering paste I use is very cheap and last very long and I apply it with a plastic pry tool, there are other better methods to apply such as the type that comes in a syringe style tube.You will also need desoldering wire or (wick) which conducts heat well and therefore absorbs the old solder.
  2. Desoldering Technique: étape 2, image 1 de 3 Desoldering Technique: étape 2, image 2 de 3 Desoldering Technique: étape 2, image 3 de 3
    • It is very helpful to add some soldering paste to the area of the logic board you will be removing solder from—it will help make the process easier and prevent from possibly pulling a pad off the logic board. I am desoldering the + and - battery connections above the SPK points in the picture.
    • Apply the de-soldering wick to the area you are removing the solder from and hold the solder gun on it so it can soak the solder up in the wick. Be very careful to not leave the solder gun on too long as the logic board components are very fragile.
    • Carefully remove the soldering iron and the wick at the same time. If you remove the solder gun first and then the wick the solder can harden and you could possibly pull components off the board. As you can see the solder pads on the logic board are clean with no excess and ready for fresh solder.
Ligne d'arrivée
30 autres ont terminé cette réparation.
John Bowers
Membre depuis le 01/18/11
868 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 11
Total : 2,238
