Aller au contenu principal
Dewalt DCD778 Forward/Reverse Switch Replacement
Ce dont vous avez besoin
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: étape 1, image 1 de 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: étape 2, image 1 de 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: étape 3, image 1 de 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: étape 4, image 1 de 1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: étape 5, image 1 de 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: étape 6, image 1 de 1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: étape 7, image 1 de 1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Brittany
Membre depuis le 03/09/19
693 Réputation
5 tutoriels rédigés
Équipe
Casper College, Team S1-G5, Lareau Spring 2019 Membre de l'équipe Casper College, Team S1-G5, Lareau Spring 2019
CASC-LAREAU-S19S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 39
Total : 1,693
