Aller au contenu principal
Dewalt Nailers DCN21PL 2018 Main Electronics Replacement
Ce dont vous avez besoin
  1. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove the battery: étape 1, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove the battery: étape 1, image 2 de 2
    • Before you begin the repair, remove the battery from the device.
  2. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove casing screws: étape 2, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove casing screws: étape 2, image 2 de 2
    • Use a T10 driver to remove the four screws securing the bottom half of the casing.
    • Remove the four T10 screws securing the top half of the casing.
  3. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove the magazine: étape 3, image 1 de 1
    • Use a T10 driver to remove the screw securing the magazine to the base.
  4. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 4, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 4, image 2 de 2
    • Pull the magazine down and away to unlatch and release it from the nailer.
  5. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove framing hook: étape 5, image 1 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove framing hook: étape 5, image 2 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove framing hook: étape 5, image 3 de 3
    • Use a T15 driver to remove the framing hook retaining screw.
    • Remove the hook.
  6. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove hook clamp: étape 6, image 1 de 1
    • This step may require a lot of force.
    • Use your two thumbs to firmly spread the metal hook clamp apart while slowly pushing it forward off the handle.
    • When this clamp is being removed, it has a tendency to launch off of the handle after you release tension.
  7. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 7, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 7, image 2 de 2
    • Use a sharp blade to slice the label underneath the battery mount to disconnect the two halves of the case.
    • Always cut away from you or others around you.
  8. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 8, image 1 de 1
    • Use a T20 driver to remove the two screws securing the two halves of the case to the front assembly.
  9. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove return system: étape 9, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove return system: étape 9, image 2 de 2
    • Use the provided 3.5 mm hex key to remove the two return system bolts on either side of the nailer.
  10. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 10, image 1 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 10, image 2 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 10, image 3 de 3
    • Grab the end cap and slide the return system assembly out of the back of the nailer to remove it.
  11. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 11, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 11, image 2 de 2
    • Use a small flathead screwdriver in the gap between the two halves of the casing near the trigger to pry the two halves apart.
  12. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 12, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 12, image 2 de 2
    • Use a small flathead screwdriver near the top seam to continue prying the case apart .
  13. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove right half of case: étape 13, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove right half of case: étape 13, image 2 de 2
    • Once loose, lift up to remove the right half of the clamshell case.
  14. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove lens cover: étape 14, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove lens cover: étape 14, image 2 de 2
    • Remove the plastic lens cover.
  15. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove board and switches: étape 15, image 1 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove board and switches: étape 15, image 2 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove board and switches: étape 15, image 3 de 3
    • The two switches and four detent springs are only held in place by the plastic casing, so they may fall out when you remove the board—this is fine.
    • Grasp either side of the main circuit board and slowly pull it up and out of the slot in the casing.
    • Reassembly tip: note the correct location and orientation of the two switches and their detent springs.
  16. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove trigger lock: étape 16, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove trigger lock: étape 16, image 2 de 2
    • Pull up on the trigger lock to remove.
  17. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove left half of case: étape 17, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove left half of case: étape 17, image 2 de 2
    • Flip the nailer over.
    • Remove the remaining clamshell casing.
  18. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement, Remove main electronics: étape 18, image 1 de 1
    • Use wire snips to cut the small black cable tie securing the four main board wires together.
  19. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 19, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 19, image 2 de 2
    • Pull the white plastic actuator straight up off its axle to remove.
  20. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 20, image 1 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 20, image 2 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 20, image 3 de 3
    • Insert the point of a pick tool into the push-in connector's inlet hole, which has the main board wire plugged into it.
    • With the pick tool still inserted, pull the red main board wire out of the push-in connector.
    • Make sure you choose the inlet that connects to the main board, not the solenoid.
    • Repeat this same process for the black wire and other push-in connector.
  21. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 21, image 1 de 2 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 21, image 2 de 2
    • Use a T20 driver to remove the following screws:
    • Two 15 mm-long board retaining screws, one on either side.
    • Three 10 mm-long motor wire screws.
  22. Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 22, image 1 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 22, image 2 de 3 Dewalt Nailers DCN21PL 2018 Main Electronics Replacement: étape 22, image 3 de 3
    • Slide the board off its guide pin to remove.
    • Reassembly tip: make sure the actuator plunger lines up with the guide hole on the main board housing.
Carsten Frauenheim
Membre depuis le 03/10/20
118 986 Réputation
341 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 078 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 19
30 derniers jours : 47
Total : 1,218
