Introduction
This guide shows how to remove or replace the main board electronics in a Dewalt DCN21PL Nailer.
Ce dont vous avez besoin
Before you begin the repair, remove the battery from the device.
Use a T10 driver to remove the four screws securing the bottom half of the casing.
Remove the four T10 screws securing the top half of the casing.
Use a T10 driver to remove the screw securing the magazine to the base.
Use a T15 driver to remove the framing hook retaining screw.
Remove the hook.
Use your two thumbs to firmly spread the metal hook clamp apart while slowly pushing it forward off the handle.
Use the provided 3.5 mm hex key to remove the two return system bolts on either side of the nailer.
Once loose, lift up to remove the right half of the clamshell case.
Grasp either side of the main circuit board and slowly pull it up and out of the slot in the casing.
Flip the nailer over.
Remove the remaining clamshell casing.
Use wire snips to cut the small black cable tie securing the four main board wires together.
Insert the point of a pick tool into the push-in connector's inlet hole, which has the main board wire plugged into it.
With the pick tool still inserted, pull the red main board wire out of the push-in connector.
Repeat this same process for the black wire and other push-in connector.
