Introduction
This guide will cover the disassembly and replacement of the battery for the Digiland DL700D. The battery is attached to the mainboard by soldered wires, so some soldering will be required. We recommend reviewing iFixit's soldering guide here.
Remove the device's back cover using the plastic opening tool.
  • Remove the device's back cover using the plastic opening tool.
Ajouter un commentaire
Remove the three pieces of adhesive placed over the edges of the battery.
  • Remove the three pieces of adhesive placed over the edges of the battery.
  • Remove the wifi antenna from the bottom of the battery.
  • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  • Remove the battery from the casing using a nylon spudger.
  • Be careful not to puncture the battery casing.
  • Carefully peel the battery free from the casing.
To reassemble your device, follow instructions in the reverse order. Apply new Kapton Tape and apply extra solder as needed.
Justin Edwards
Membre depuis le 29/03/2018
241 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G4, Harley Spring 2018 Membre de l'équipe IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 59
