Introduction
This guide will show how to replace the mainboard in the event of failure. The process is relatively simple, though some soldering will be required. It is advised to review soldering techniques here.
Remove the device's back cover using the plastic opening tool.
  • Remove the device's back cover using the plastic opening tool.
Ajouter un commentaire
Remove the three pieces of adhesive placed over the edges of the battery.
  • Remove the three pieces of adhesive placed over the edges of the battery.
  • Remove the wifi antenna from the bottom of the battery.
  • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  • Remove the battery from the casing using a nylon spudger.
  • Be careful not to puncture the battery casing.
  • Carefully peel the battery free from the casing.
  • Desolder the WiFi antenna from the motherboard.
  • Remove 3 ribbon cables attached to the motherboard by lifting the plastic retainer, then pulling the cable out.
  • Remove adhesive attaching the motherboard to the casing.
  • Remove the three 2.5 mm Phillips #1 screws holding the motherboard to the case.
  • Remove motherboard from the case and replace.
To reassemble, follow these instructions in reverse order.
Justin Edwards
Membre depuis le 29/03/2018
241 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G4, Harley Spring 2018 Membre de l'équipe IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 59
