Aller au contenu principal
DigiLand DL701Q Back Case Replacement
Ce dont vous avez besoin
  1. DigiLand DL701Q Back Case Replacement, Back Case: étape 1, image 1 de 3 DigiLand DL701Q Back Case Replacement, Back Case: étape 1, image 2 de 3 DigiLand DL701Q Back Case Replacement, Back Case: étape 1, image 3 de 3
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: étape 2, image 1 de 3 DigiLand DL701Q Back Case Replacement: étape 2, image 2 de 3 DigiLand DL701Q Back Case Replacement: étape 2, image 3 de 3
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
2 autres ont terminé cette réparation.
Jonathan Mysona
Membre depuis le 03/21/16
1 135 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 6-1, Benson Spring 2016 Membre de l'équipe Clemson, Team 6-1, Benson Spring 2016
CLEM-BENSON-S16S6G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 6
Total : 880
