Introduction
This guide will teach the user how to remove every component safely and replace the screen of the Digiland DL701Q tablet.
Ce dont vous avez besoin
Hold the device firmly, in landscape view.
Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
Lay device flat on the table.
Firmly grip the device on the edges. Take the wedge portion of the spudger tool and push in between the battery and the screen with force. Begin pushing the spudger with the wedge underneath the battery all the way around in order to break the glue.
Repeat this step pushing further across and underneath until the battery is loose.
Orient the device with the screen facing down as shown in the picture and locate the speaker.
Locate where the flash's wires connect to the motherboard.
Desolder the speaker's wires from the motherboard and remove the speaker by pulling gently to see if the wires have been desoldered.
First orient the device to a portrait position as seen in the picture.
Locate the zero insertion force (ZIF) connector shown in the figure.
Use the tweezers to pull up on the zero insertion force (ZIF) connector and release the ribbon.
Next, take the tweezers and grab the ribbon and pull outward from the socket.
With the device flat on the table in the portrait position, grip the device and locate the antenna.
There is a connection at the top of the device. Desolder the connection.
Now locate the last connection that is attached near the bottom of the device. Desolder this connection.
Use the tweezers to pry up the antenna strip
Locate the two 3mm screws.
Remove the two 3mm screws using the PH0 screwdriver.
7 autres ont terminé cette réparation.
