Aller au contenu principal
DigiLand DL8006 Speaker Replacement
Ce dont vous avez besoin
  1. DigiLand DL8006 Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: étape 2, image 1 de 2 DigiLand DL8006 Speaker Replacement: étape 2, image 2 de 2
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: étape 3, image 1 de 2 DigiLand DL8006 Speaker Replacement: étape 3, image 2 de 2
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: étape 4, image 1 de 3 DigiLand DL8006 Speaker Replacement: étape 4, image 2 de 3 DigiLand DL8006 Speaker Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: étape 5, image 1 de 1
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: étape 6, image 1 de 2 DigiLand DL8006 Speaker Replacement: étape 6, image 2 de 2
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
Alec Trela
Membre depuis le 10/30/19
327 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team S2-G5, Kim Fall 2019 Membre de l'équipe University of Memphis, Team S2-G5, Kim Fall 2019
UM-KIM-F19S2G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 10
Total : 143
