Aller au contenu principal
DigiTech RP70 DC Power Connector Replacement
Ce dont vous avez besoin
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: étape 1, image 1 de 2 DigiTech RP70 DC Power Connector Replacement, Motherboard: étape 1, image 2 de 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: étape 2, image 1 de 2 DigiTech RP70 DC Power Connector Replacement: étape 2, image 2 de 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: étape 3, image 1 de 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: étape 4, image 1 de 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: étape 5, image 1 de 1
    • Desolder the back of the motherboard where the power connector is located.
Elijah Smith
Membre depuis le 09/10/18
738 Réputation
6 tutoriels rédigés
Un commentaire
Later? I cant see to other
ISAAC SALAZAR - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 325
