Ce dont vous avez besoin
Étape 1 Digiland 10.1'' DL1016 Remove Backing
Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Étape 4 Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard
Attention : l'étape 4 est issue d'un tutoriel marqué comme en cours.
Gently pull the wiring back.
Disconnect the black cable off the motherboard.
Remove the four 1.5mm Phillips #000 screws from the motherboard.
Once you have followed all steps simply replace the motherboard to fix your RAM
To reassemble your device, follow these instructions in reverse order. When following the Prerequisite Guide for Replacing the Power Button ONLY go to step 7.
