Aller au contenu principal
Digiland 10.1'' DL1016 Motherboard Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
    Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Remove Backing: étape 1, image 1 de 2 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Remove Backing: étape 1, image 2 de 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Motherboard Replacement: étape 2, image 1 de 2 Digiland 10.1'' DL1016 Motherboard Replacement: étape 2, image 2 de 2
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: étape 3, image 1 de 3 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: étape 3, image 2 de 3 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: étape 3, image 3 de 3
    • Pull back the black flaps on the ZIF cable connectors.
    • Pull the ribbon cables out of the connectors.
  4. Attention : l'étape 4 est issue d'un tutoriel marqué comme en cours.
    Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: étape 4, image 1 de 2 Digiland 10.1'' DL1016 Motherboard Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: étape 4, image 2 de 2
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  5. Digiland 10.1'' DL1016 Motherboard Replacement, Power Button: étape 5, image 1 de 1
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Motherboard Replacement: étape 6, image 1 de 2 Digiland 10.1'' DL1016 Motherboard Replacement: étape 6, image 2 de 2
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Motherboard Replacement, Motherboard: étape 7, image 1 de 1
    • Once you have followed all steps simply replace the motherboard to fix your RAM
To reassemble your device, follow these instructions in reverse order. When following the Prerequisite Guide for Replacing the Power Button ONLY go to step 7.
Virginia Tapia
Membre depuis le 08/26/19
386 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team S1-G2, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 529
