Aller au contenu principal
Digiland 10.1'' DL1016 Power Button Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
    Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Remove Backing: étape 1, image 1 de 2 Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Remove Backing: étape 1, image 2 de 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Power Button Replacement: étape 2, image 1 de 2 Digiland 10.1'' DL1016 Power Button Replacement: étape 2, image 2 de 2
    • Gently lift the backing off.
  3. Attention : l'étape 3 est issue d'un tutoriel marqué comme en cours.
    Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: étape 3, image 1 de 2 Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: étape 3, image 2 de 2
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Power Button Replacement, Power Button: étape 4, image 1 de 1
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  5. Digiland 10.1'' DL1016 Power Button Replacement: étape 5, image 1 de 2 Digiland 10.1'' DL1016 Power Button Replacement: étape 5, image 2 de 2
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
CRISTIAN RAMIREZ
Membre depuis le 08/26/19
85 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G2, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 membres
5 tutoriels rédigés
2 commentaires
I want to know if ebay cheap 1 count usb charge port. Is okay to buy 4 This tablet. It is $3 or less & is all I need, I think. Just broke my tablet way worse on sloppy job of screen replacement , but it look ok. You see lint hair, etc underneath when screen off at an angle close uo is all & ruined power button area ceazy glue, etc mess I have to press down hard with something & now on top of all, the charger chord at same time plys charge lose all of a sudden so it isnt really charging or a hassle & if it is it turns off while playing on a game. etc. Now it is not even turning on. Just tries, but doesn't. At least b4 it was. I took it apart to see the charge port . Good thing its not a cable type & can easily replace for cheaoer then one too. I has wrong battery reading or diff on screen off then on have 2opush down, but charge port lose. I don’t know if replacing will fix it or it has other issue when I messed up the power button. I need 2 try the port till I can buy other tablet. If I had not broke it been okay. Lesson learned
Lily R - Réponse
I had more to say just a bit, but I didn’t copy to paste it on 2nd post & I wish I had. S I'll n e went over chrts I just back arrow backspace deleted. Oh well. Nvm.
Lily R - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 649
