Aller au contenu principal
Digiland DL1168A Front/Rear Camera Replacement
Ce dont vous avez besoin
  1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: étape 1, image 1 de 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Front/Rear Camera Replacement: étape 2, image 1 de 2 Digiland DL1168A Front/Rear Camera Replacement: étape 2, image 2 de 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Front/Rear Camera Replacement: étape 3, image 1 de 2 Digiland DL1168A Front/Rear Camera Replacement: étape 3, image 2 de 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the cover that keeps the camera lens in place.
  5. Digiland DL1168A Front/Rear Camera Replacement: étape 5, image 1 de 1
    • Use tweezers to gently begin to lift the back piece off.
    • Lift gently because the lens is connected to the back piece by a small cord.
  6. Digiland DL1168A Front/Rear Camera Replacement: étape 6, image 1 de 1
    • After lifting gently both the lens and the back piece will be removed.
Payton Boshears
Membre depuis le 10/15/19
97 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 112
