Aller au contenu principal
Digiland DL1168A Motherboard Replacement
Ce dont vous avez besoin
  1. Digiland DL1168A Motherboard Replacement, Rear Case: étape 1, image 1 de 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Motherboard Replacement: étape 2, image 1 de 2 Digiland DL1168A Motherboard Replacement: étape 2, image 2 de 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Motherboard Replacement: étape 3, image 1 de 2 Digiland DL1168A Motherboard Replacement: étape 3, image 2 de 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Motherboard Replacement, Motherboard: étape 4, image 1 de 2 Digiland DL1168A Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, carefully lift the three zero insertion force connectors (ZIF) attached to the motherboard.
  5. Digiland DL1168A Motherboard Replacement: étape 5, image 1 de 2 Digiland DL1168A Motherboard Replacement: étape 5, image 2 de 2
    • Using the soldering iron, desolder all eight wires connected to the motherboard.
    • Removing the red wire then the black wire (2 wires).
    • Desolder the three wires and remove them.
    • Remove the single grey wire.
    • Remove the yellow and red twisted wires and black and red twisted wires connected to the speakers.
  6. Digiland DL1168A Motherboard Replacement: étape 6, image 1 de 2 Digiland DL1168A Motherboard Replacement: étape 6, image 2 de 2
    • Remove the four 4mm Phillips #00 screws attached to the motherboard.
  7. Digiland DL1168A Motherboard Replacement: étape 7, image 1 de 1
    • Gently lift and remove the motherboard using the iFixit opening tool.
Katelyn Wilkerson
Membre depuis le 10/15/19
159 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 112
