Aller au contenu principal
Digital2 D2-912 Battery Replacement
Ce dont vous avez besoin
  1. Digital2 D2-912 Battery Replacement, External Cover: étape 1, image 1 de 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Battery Replacement: étape 2, image 1 de 2 Digital2 D2-912 Battery Replacement: étape 2, image 2 de 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Battery Replacement, Battery: étape 3, image 1 de 2 Digital2 D2-912 Battery Replacement, Battery: étape 3, image 2 de 2
    • The battery to be removed is shown with the red box in the photo.
    • Gently remove the battery from the tablet by sliding the metal spudger under the battery.
    • There is glue holding the battery in place, so this step requires some finesse.
    • At this point, your battery should still be attached to the tablet by a red and black wire.
  4. Digital2 D2-912 Battery Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Desoldering Pump
    $3.99
    J'achète
    • Take note of which wire goes where (black wire below red wire in photo).
    • In gold writing, 'bat+' indicates the positive terminal (location of red wire), and 'bat-' indicates the negative terminal (location of black wire).
    • To remove the wires from their terminals, use a soldering iron and a solder sucker.
    • Refer to the ifixit solder guide to learn more about how to solder.
    • Attach the black (negative) and red (positive) wires of the new/replacement batteryrespectively to their terminals by soldering them.
    • Position the battery in it's original location, secure with glue.
Lindsay Richardson
Membre depuis le 09/16/15
394 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Harley Fall 2015 Membre de l'équipe IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,022
