Aller au contenu principal
Direct-Drive Turntable Cartridge and Needle Replacement
Ce dont vous avez besoin
  1. Direct-Drive Turntable Cartridge and Needle Replacement, Cartridge and Needle: étape 1, image 1 de 1
    • Check the needle and cartridge to see if they need to be replaced.
    • If the cartridge is touching your vinyl, it must be replaced.
    • Additionally, if you can hear scraping when playing the record, or if you see new scratch marks on the vinyl, it is time to change the cartridge and needle.
  2. Direct-Drive Turntable Cartridge and Needle Replacement: étape 2, image 1 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 2, image 2 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 2, image 3 de 3
    • Manually unscrew the bulb on the tone arm from the headshell.
    • Pull out the headshell once it is completely unscrewed from the tone arm.
  3. Direct-Drive Turntable Cartridge and Needle Replacement: étape 3, image 1 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 3, image 2 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    J'achète
    • Use a 2.5 mm flathead screwdriver to remove both screws from the headshell.
  4. Direct-Drive Turntable Cartridge and Needle Replacement: étape 4, image 1 de 2 Direct-Drive Turntable Cartridge and Needle Replacement: étape 4, image 2 de 2
    • Gently pull the four wires out from the back of the cartridge.
  5. Direct-Drive Turntable Cartridge and Needle Replacement: étape 5, image 1 de 2 Direct-Drive Turntable Cartridge and Needle Replacement: étape 5, image 2 de 2
    • Pull the needle off of the new cartridge to ensure it does not get damaged during installation.
  6. Direct-Drive Turntable Cartridge and Needle Replacement: étape 6, image 1 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 6, image 2 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 6, image 3 de 3
    • Connect the wires on the headshell to the new cartridge by matching the colors of the wires to the pins on the cartridge.
    • Place the headshell back onto the cartridge, being sure to line up the holes for the screws.
    • Place the screws back into the holes connecting the headshell and the new cartridge.
  7. Direct-Drive Turntable Cartridge and Needle Replacement: étape 7, image 1 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 7, image 2 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 7, image 3 de 3
    • Screw the screws in using a 2.5 mm flathead screwdriver. Ensure the headshell is securely attached to the cartridge.
    • Slide the new needle back onto the cartridge.
  8. Direct-Drive Turntable Cartridge and Needle Replacement: étape 8, image 1 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 8, image 2 de 3 Direct-Drive Turntable Cartridge and Needle Replacement: étape 8, image 3 de 3
    • Attach the headshell to the tone arm and screw the headshell in from the tip of the tone arm.
    • Ensure that the headshell is secured in the tone arm and that there is no movement in the headshell when connected to the tone arm.
  9. Direct-Drive Turntable Cartridge and Needle Replacement: étape 9, image 1 de 1
    • Place the needle onto a vinyl record and ensure that only the tip of the needle is touching the record and not the cartridge.
Ligne d'arrivée
Dylan Udhesister
Membre depuis le 09/18/20
169 Réputation
1 tutoriel rédigé
Équipe
York University, Team S3-G64, Melo-Thaiss Fall 2020 Membre de l'équipe York University, Team S3-G64, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G64
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 30
Total : 868
