Aller au contenu principal
Dis/assembling Eye/Pupil Camera Housing
Ce dont vous avez besoin
  1. Dis/assembling Eye/Pupil Camera Housing, Dis/assembling Eye/Pupil Camera Housing: étape 1, image 1 de 1
    • First: Eye Camera
    • Remove initial frame (crack off)
  2. Dis/assembling Eye/Pupil Camera Housing: étape 2, image 1 de 1
    • Remove 4 screws.
  3. Dis/assembling Eye/Pupil Camera Housing: étape 3, image 1 de 1
    • Remove cover to get to the PCB underneath
  4. Dis/assembling Eye/Pupil Camera Housing: étape 4, image 1 de 1
    • Remove two screws on the PCB.
  5. Dis/assembling Eye/Pupil Camera Housing: étape 5, image 1 de 1
    • Remove PCB from the base plastic piece.
  6. Dis/assembling Eye/Pupil Camera Housing: étape 6, image 1 de 1
    • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
  7. Dis/assembling Eye/Pupil Camera Housing: étape 7, image 1 de 1
    • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
  8. Dis/assembling Eye/Pupil Camera Housing: étape 8, image 1 de 1
    • Completed assembly of the eye camera.
  9. Dis/assembling Eye/Pupil Camera Housing, Pupil camera dis/assembly: étape 9, image 1 de 1
    • Back of pupil camera is glued on. Remove with flat-head.
  10. Dis/assembling Eye/Pupil Camera Housing: étape 10, image 1 de 1
    • Remove the black frame on the front of the pupil camera.
  11. Dis/assembling Eye/Pupil Camera Housing: étape 11, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 11, image 2 de 2
    • Once frame is taken off the front, two screws need to be removed.
  12. Dis/assembling Eye/Pupil Camera Housing: étape 12, image 1 de 1
    • One screw removed from the back.
  13. Dis/assembling Eye/Pupil Camera Housing: étape 13, image 1 de 1
    • Front housing comes off once the screws are removed from the frame.
    • Twist out the silver microphone.
  14. Dis/assembling Eye/Pupil Camera Housing: étape 14, image 1 de 1
    • Pull off bottom stand until it breaks off.
  15. Dis/assembling Eye/Pupil Camera Housing: étape 15, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 15, image 2 de 2
    • Remove rubber/plastic piece from the bottom
  16. Dis/assembling Eye/Pupil Camera Housing: étape 16, image 1 de 1
    • Remove four screws from under the plastic tape (removed from last step).
  17. Dis/assembling Eye/Pupil Camera Housing: étape 17, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 17, image 2 de 2
    • Bottom pops off
  18. Dis/assembling Eye/Pupil Camera Housing: étape 18, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 18, image 2 de 2
    • Separate the metal frame from the plastic assembly.
    • Avoid the cables
  19. Dis/assembling Eye/Pupil Camera Housing: étape 19, image 1 de 1
    • Take out PCB from the plastic housing.
  20. Dis/assembling Eye/Pupil Camera Housing: étape 20, image 1 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 20, image 2 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 20, image 3 de 3
    • Remove the rest of the black plastic housing.
  21. Dis/assembling Eye/Pupil Camera Housing: étape 21, image 1 de 1
    • Black plastic housing removed
  22. Dis/assembling Eye/Pupil Camera Housing: étape 22, image 1 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 22, image 2 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 22, image 3 de 3
    • Continue removing the black plastic housing surrounding the inner PCB.
  23. Dis/assembling Eye/Pupil Camera Housing: étape 23, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 23, image 2 de 2
    • PCB removed from the black plastic housing.
  24. Dis/assembling Eye/Pupil Camera Housing: étape 24, image 1 de 1
    • Autofocus assembly.
    • Remove two screws from the bottom of the auto-focus PCB.
  25. Dis/assembling Eye/Pupil Camera Housing: étape 25, image 1 de 1
    • Unscrew the lens
  26. Dis/assembling Eye/Pupil Camera Housing: étape 26, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 26, image 2 de 2
    • Take out the IR filter by using a scalpel for pulling out the lens tape.
  27. Dis/assembling Eye/Pupil Camera Housing: étape 27, image 1 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 27, image 2 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 27, image 3 de 3
    • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
  28. Dis/assembling Eye/Pupil Camera Housing: étape 28, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 28, image 2 de 2
    • IR LEDs replaced by SMD LED
    • Soldering required here (at bottom of LED to remove).
  29. Dis/assembling Eye/Pupil Camera Housing: étape 29, image 1 de 1
    • SMD LED info: Thick black line is near the positive side of the LED
    • Dark side (dot) is positive side on LED.
  30. Dis/assembling Eye/Pupil Camera Housing: étape 30, image 1 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 30, image 2 de 3 Dis/assembling Eye/Pupil Camera Housing: étape 30, image 3 de 3
    • Insert PCB into 3d-printed frame.
  31. Dis/assembling Eye/Pupil Camera Housing: étape 31, image 1 de 2 Dis/assembling Eye/Pupil Camera Housing: étape 31, image 2 de 2
    • Completed assembly.
    • Sugru used for nose/head rest
2 autres ont terminé cette réparation.
Silas
Membre depuis le 11/25/13
318 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 12
Total : 661
