Introduction
Disassembly
1. Flip toaster over.
2. Locate four phillips screws on the bottom of the toaster.
3. Loosen and remove.
4. Sides will pop out once screws are removed.
  1. 1. Flip toaster over.
    • 1. Flip toaster over.
  2. 2. Locate four phillips screws on the bottom of the toaster.
    • 2. Locate four phillips screws on the bottom of the toaster.
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  4. 3. Loosen and remove using a Phillips head screwdriver
    • 3. Loosen and remove using a Phillips head screwdriver
  5. 4. Sides will pop out once screws are removed.
    • 4. Sides will pop out once screws are removed.
Carlos
Membre depuis le 23/07/2013
101 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team 2-5, Bradley Summer 2013 Membre de l'équipe UC Santa Barbara, Team 2-5, Bradley Summer 2013
UCSB-BRADLEY-R13S2G5
6 membres
1 tutoriel rédigé
Hi Carlos,
Before removing the cover I need to remove the PUSH LEVER.
Please forward instructions on HOW TO REMOVE THE PUSH LEVER.
Thank you.
Earle
earleb - Réponse
I Disassembled, cleaned and put it back together.  However the purpose of the exercise was to fix the browning feature or timing issue.  the little plastic bit that goes from the browning turn knob does not function.  So the push knob does not stay down.  This results in having to hold the push knob down till the toast is done to my satisfaction.  The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
Allan Rodrigues - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 691
