Aller au contenu principal
Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body
Ce dont vous avez besoin
  1. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body, Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: étape 1, image 1 de 1
    • 1. Flip toaster over.
  2. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: étape 2, image 1 de 1
    • 2. Locate four phillips screws on the bottom of the toaster.
  3. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: étape 3, image 1 de 1
    • 3. Loosen and remove using a Phillips head screwdriver
  4. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: étape 4, image 1 de 1
    • 4. Sides will pop out once screws are removed.
2 autres ont terminé cette réparation.
Carlos
Membre depuis le 07/23/13
113 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team 2-5, Bradley Summer 2013 Membre de l'équipe UC Santa Barbara, Team 2-5, Bradley Summer 2013
UCSB-BRADLEY-R13S2G5
6 membres
1 tutoriel rédigé
3 commentaires
Hi Carlos,
Before removing the cover I need to remove the PUSH LEVER.
Please forward instructions on HOW TO REMOVE THE PUSH LEVER.
Thank you.
Earle
earleb - Réponse
I Disassembled, cleaned and put it back together.  However the purpose of the exercise was to fix the browning feature or timing issue.  the little plastic bit that goes from the browning turn knob does not function.  So the push knob does not stay down.  This results in having to hold the push knob down till the toast is done to my satisfaction.  The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
Allan Rodrigues - Réponse
To slide down the toast, the lever does not go down completely, leaving the top of bread exposed. Is there a way to adjust the depth the toast goes down? If so, could you send me instructions. Thank you
Christina - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 10
Total : 1,871
