Aller au contenu principal
Disassembling 8BitDo Pro 2 Wired Joystick Board
Ce dont vous avez besoin
  1. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove R2 and L2 pads: étape 1, image 1 de 2 Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove R2 and L2 pads: étape 1, image 2 de 2
    • Remove both pads by pushing them up.
  2. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove T6 Screws: étape 2, image 1 de 1
    • Remove both Torx T6 screws from the back.
  3. Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: étape 3, image 1 de 3 Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: étape 3, image 2 de 3 Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: étape 3, image 3 de 3
    • With an opening pick, detach the seven clips holding the faceplate. Start from the sides, towards the bottom.
    • Detach the remaining clips by carefully raising the faceplate away from the clips.
    • A flex cable joins both plates.
    • Move the faceplate to the side.
  4. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the flex cable: étape 4, image 1 de 1
    • Push the sides of the connector away from it to free the cable.
  5. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the #0 screws: étape 5, image 1 de 1
    • Remove the 8 screws using a Phillips #0 screwdriver.
    • You can remove the joystick caps by lifting them.
  6. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the board: étape 6, image 1 de 2 Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the board: étape 6, image 2 de 2
    • Slowly lift the board from the controller. Make sure to lift both rumble motors as well.
Adrián
Membre depuis le 01/22/23
173 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 90
Total : 443
