Aller au contenu principal
Removing DVD Drive from Acer Aspire 5100
Ce dont vous avez besoin
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: étape 1, image 1 de 2 Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: étape 1, image 2 de 2
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: étape 2, image 1 de 1
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: étape 3, image 1 de 2 Removing DVD Drive from Acer Aspire 5100: étape 3, image 2 de 2
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: étape 4, image 1 de 2 Removing DVD Drive from Acer Aspire 5100: étape 4, image 2 de 2
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: étape 5, image 1 de 1
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
To reassemble, follow above steps in reverse.
2 autres ont terminé cette réparation.
luis
Membre depuis le 04/21/10
167 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-66, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 18-66, Johann Spring 2010
CPSU-JOHANN-S10S18G66
5 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 2,768
