Aller au contenu principal
Disassembling Acer Iconia A1-830 Back Panel
Ce dont vous avez besoin
  1. Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: étape 1, image 1 de 2 Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: étape 1, image 2 de 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Disassembling Acer Iconia A1-830 Back Panel: étape 2, image 1 de 2 Disassembling Acer Iconia A1-830 Back Panel: étape 2, image 2 de 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
10 autres ont terminé cette réparation.
Matt Champagne
Membre depuis le 10/20/15
458 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 membres
5 tutoriels rédigés
2 commentaires
Hi iv got an acer icon is one 10.iv done a factory reset ,but it hasent come back ,and it turns on but I can't stop it talking ,volume won't turn down and ,when I checked the volume button it says it turn off .the tablet won't do anything .can you tell me if it's worth repairing and how much if possible. Thank you Teresa spry
Teresa Spry - Réponse
Can the back of the tablet be completely removed, so i can look at the micro USB port, to see if that is what is not letting the tablet charge !! Without not knowing what I’m doing and messing it up!!
andre_chatel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 6,042
