Aller au contenu principal
Disassembling Beats Pill 1.0
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Disassembling Beats Pill 1.0, Removing the Case Screws: étape 1, image 1 de 3 Disassembling Beats Pill 1.0, Removing the Case Screws: étape 1, image 2 de 3 Disassembling Beats Pill 1.0, Removing the Case Screws: étape 1, image 3 de 3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
  2. Disassembling Beats Pill 1.0, Removing Center Cover: étape 2, image 1 de 3 Disassembling Beats Pill 1.0, Removing Center Cover: étape 2, image 2 de 3 Disassembling Beats Pill 1.0, Removing Center Cover: étape 2, image 3 de 3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Disassembling Beats Pill 1.0, Separate the Device: étape 3, image 1 de 3 Disassembling Beats Pill 1.0, Separate the Device: étape 3, image 2 de 3 Disassembling Beats Pill 1.0, Separate the Device: étape 3, image 3 de 3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: étape 4, image 1 de 2 Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: étape 4, image 2 de 2
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: étape 5, image 1 de 2 Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: étape 5, image 2 de 2
    • Carefully remove the black and red NFC sensor wires.
  6. Disassembling Beats Pill 1.0, Disconnect Control Wiring: étape 6, image 1 de 2 Disassembling Beats Pill 1.0, Disconnect Control Wiring: étape 6, image 2 de 2
    • Carefully remove the control cables (4 black, 1 red).
To reassemble your device, simply follow the disassembly guide in reverse. If you have questions or concerns about the disassembly of your device, please see the device page or troubleshooting page for the Beats Pill 1.0 for more information.
5 autres ont terminé cette réparation.
Équipe
USF Tampa, Team 5-4, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 4,384
