Danger
Potentiellement dangereux
Risque de blessure si cette procédure n'est pas suivie correctement. Faites preuve de prudence et suivez tous les avertissements.
Danger
Introduction
This speaker contains 3 main PCB's. One is for audio control, one is for power control, and the other (and largest) is for audio amplification. To access any of them for replacement, you must first open up the metal electronics box.
Pièces
Aucune pièce nécessaire.
Unplug your speaker from the power outlet.
  • Unplug your speaker from the power outlet.
  • Remove the 8 Phillips screws from the back of the speaker.
Ajouter un commentaire
Carefully remove the back panel, lifting out the metal electronics-box with it.
  • Carefully remove the back panel, lifting out the metal electronics-box with it.
  • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
  • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
  • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
  • You should have removed a total of 7 machine screws and 2 washers.
  • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
  • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
  • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
  • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
  • Snake the clip head through the hole in the metal electronics box casing.
  • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
  • Rotate the back panel so you can view the interior; note the three wires attached.
  • Remove the wires to you can fully remove the back panel.
gameslammer7
Membre depuis le 29/03/2012
861 Réputation
6 tutoriels rédigés
[|hello sir i am using behringer b215 d eurolive active speaker and power controler ic shot in one spesker and his ic code is this]-VIPer22A (4C6107) and please solve my this problems can you help me
ANWAR ALI WARSI - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 64
Total : 3,606
