Introduction
This guide will show you how to open your drill so that you can fix any problems that require you to open it up and possibly remove or replace parts. This guide is prerequisite only.
Pièces
Aucune pièce nécessaire.
  1. Remove the nine 15mm Philips #1 screws Remove the two 12.5mm Philips #1 screws Remove the two 10mm Philips #1 screws
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
2 autre(s) ont terminé cette réparation.
Jonathon Centofranchi
Membre depuis le 19/04/2013
240 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-15, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 1,377
