Aller au contenu principal
Disassembling Canon Pixma MP480 Rear and Side Panel
Ce dont vous avez besoin
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: étape 1, image 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: étape 1, image 2 de 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 2, image 1 de 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 3, image 1 de 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 4, image 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: étape 4, image 2 de 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 5, image 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: étape 5, image 2 de 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 6, image 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: étape 6, image 2 de 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 7, image 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: étape 7, image 2 de 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: étape 8, image 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: étape 8, image 2 de 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
6 autres ont terminé cette réparation.
Kevin Cole
Membre depuis le 01/17/13
116 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 19-41, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 membres
6 tutoriels rédigés
2 commentaires
Where is the rest of disassembly?
bill roberts - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 29
Total : 21,158
