Aller au contenu principal
Introduction
Use this guide to remove the front and rear cover of the Canon PowerShot SD1100 IS.
Pièces
Aucune pièce spécifiée.
  1. Remove wrist strap and battery. Remove wrist strap and battery.
    • Remove wrist strap and battery.
  2. Remove 2 screws from each side of the camera (4 total, 0.102 in). Remove 2 screws from the bottom on the camera (0.138 in). Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  4. Gently pull off the front cover. The plate on the side should come off. Gently pull off the back cover.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  5. The cases should now be removed.
    • The cases should now be removed.
3 autre(s) ont terminé cette réparation.
Tyler Grossheim
Membre depuis le 25/01/2011
1 440 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,166
