Introduction
This guide is used to disassemble the lens from the camera. This will be used to further clean the lens if you experience the E18 error.
Ce dont vous avez besoin
Turn off the camera by pressing the power button above the LCD screen.
Remove the two screws that connect the LCD and backlight to the main body of the camera.
Unplug the ribbon from the housing on the circuitry.
Take the new ribbon and insert it into the housing.
Tweezers or a tool with a sharp point can be used.
Once the LCD and Backlight are detached, remove the larger screw marked in red in the picture as well as the four smaller sized screws marked in blue.
With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
Once you have removed the lens from the main chassis, gently brush off any dirt, sand, or dust that may have accumulated in the crevices. Using a compressed air canister or a brush can help remove all the dirt.
2 autres ont terminé cette réparation.
