Aller au contenu principal
Disassembling Canon PowerShot SD800 IS Front Cover
Ce dont vous avez besoin
  1. Disassembling Canon PowerShot SD800 IS Front Cover, Back Cover: étape 1, image 1 de 1
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS Front Cover: étape 2, image 1 de 1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS Front Cover: étape 3, image 1 de 1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS Front Cover: étape 4, image 1 de 1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS Front Cover, Front Cover: étape 5, image 1 de 1
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  6. Disassembling Canon PowerShot SD800 IS Front Cover: étape 6, image 1 de 1
    • Remove one 2.25mm screw on the bottom of the camera.
  7. Disassembling Canon PowerShot SD800 IS Front Cover: étape 7, image 1 de 1
    • Pull off the front cover.
Jeremy Rabaino
Membre depuis le 10/10/10
135 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-9, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 2,479
