Introduction
The LCD display can be removed and replaced if it is cracked or broken.
Outils
Pièces
Aucune pièce spécifiée.
Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
Remove the last screw (2.59 mm) located on the bottom of the camera.
Slowly pull the back cover of the camera.
Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen.
Disconnect the ribbons connecting the screen to the camera.
Lift off the screen.
