Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Remove all four screws on the side of camera with speaker.
    • Remove all four screws on the side of camera with speaker.
  2. Remove all four screws from side of camera with wristband attachment.
    • Remove all four screws from side of camera with wristband attachment.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Remove all four screws on bottom of camera.
    • Remove all four screws on bottom of camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  5. Once all screws have been removed, gently pry open bottom casing. With tweezers, carefully remove ribbon from LCD screen. Set bottom casing aside.
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  6. Pry apart the top casing using tweezers. Set the top casing aside.
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
2 autre(s) ont terminé cette réparation.
Logan
Membre depuis le 10/01/2011
311 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-38, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,804
