Aller au contenu principal
Disassembling Chef's Choice M115 Case
Ce dont vous avez besoin
  1. Disassembling Chef's Choice M115 Case, Case: étape 1, image 1 de 2 Disassembling Chef's Choice M115 Case, Case: étape 1, image 2 de 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Disassembling Chef's Choice M115 Case: étape 2, image 1 de 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Disassembling Chef's Choice M115 Case: étape 3, image 1 de 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Disassembling Chef's Choice M115 Case: étape 4, image 1 de 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
4 autres ont terminé cette réparation.
Zachary Grounds
Membre depuis le 09/17/15
580 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 membres
12 tutoriels rédigés
Un commentaire
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 20
Total : 1,442
