Pièces
Aucune pièce nécessaire.
  1. Make sure the camera is turned off here. Remove batteries from the battery compartment located on the bottom of the camera Remove SD card for the card reader compartment located on the flat side (left side)  of the camera
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Remove 2 screws on the rounded side of the camera wisdom here.
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Remove 3 screws on the flat side of the camera All silver screws go into the side of the camera that is silver
    • Remove 3 screws on the flat side of the camera
      • All silver screws go into the side of the camera that is silver
      • All black screws go into the side of the camera that is black
  5. Remove 4 screws from the bottom of the camera
    • Remove 4 screws from the bottom of the camera
  6. Separate the front and back pieces of the cameras plastic casing using a spudgerm here. WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control Use minimal force so that the plastic casing does not break
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
      • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
      • Use minimal force so that the plastic casing does not break
      • When separating the small silver sliding indicator for view/off/playback may fall out
      • The plastic viewing window located on the top of the camera may also become lose and fall out
Brittany
Membre depuis le 12/02/2013
101 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-5, Buehl Spring 2013 Membre de l'équipe Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 46
