Aller au contenu principal
Disassembling Epson PPC650 Replacing Flash
Ce dont vous avez besoin
  1. Disassembling Epson PPC650 Replacing Flash, Case: étape 1, image 1 de 3 Disassembling Epson PPC650 Replacing Flash, Case: étape 1, image 2 de 3 Disassembling Epson PPC650 Replacing Flash, Case: étape 1, image 3 de 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Disassembling Epson PPC650 Replacing Flash: étape 2, image 1 de 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Disassembling Epson PPC650 Replacing Flash: étape 3, image 1 de 2 Disassembling Epson PPC650 Replacing Flash: étape 3, image 2 de 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Disassembling Epson PPC650 Replacing Flash: étape 4, image 1 de 1
    • Remove 4 screws from the bottom of the camera
  5. Disassembling Epson PPC650 Replacing Flash: étape 5, image 1 de 3 Disassembling Epson PPC650 Replacing Flash: étape 5, image 2 de 3 Disassembling Epson PPC650 Replacing Flash: étape 5, image 3 de 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: étape 6, image 1 de 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: étape 6, image 2 de 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: étape 6, image 3 de 3
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
  7. Disassembling Epson PPC650 Replacing Flash: étape 7, image 1 de 1
    • Remove clear rubber band holding flash in line with wiring.
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
Xan Danes
Membre depuis le 02/14/13
122 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-5, Buehl Spring 2013 Membre de l'équipe Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 290
