The screws are hidden under the label. You can feel the holes by pushing on it.
Cut an X pattern in the label directly over each of the four screw holes, using a razor bade.
Back out the screws under the label using a 2.3 mm triangle screwdriver.
There are also 8 holding pins, 2 on each side of the base. Stick something in between top and bottom parts and pry open. Butter knifes worked best for me.
