Aller au contenu principal
Disassembling Flip Video Outer Shell
Ce dont vous avez besoin
  1. Disassembling Flip Video Outer Shell, Outer Shell: étape 1, image 1 de 2 Disassembling Flip Video Outer Shell, Outer Shell: étape 1, image 2 de 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Disassembling Flip Video Outer Shell: étape 2, image 1 de 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Disassembling Flip Video Outer Shell: étape 3, image 1 de 2 Disassembling Flip Video Outer Shell: étape 3, image 2 de 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Disassembling Flip Video Outer Shell: étape 4, image 1 de 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Disassembling Flip Video Outer Shell: étape 5, image 1 de 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
Elizabeth
Membre depuis le 04/15/10
100 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 26-21, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,021
