Aller au contenu principal
Disassembling Fujifilm Endeavor 100ix Outer Casing
Ce dont vous avez besoin
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: étape 1, image 1 de 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 2, image 1 de 1
    • Locate the battery door.
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 3, image 1 de 1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 4, image 1 de 1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 5, image 1 de 1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 6, image 1 de 2 Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 6, image 2 de 2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 7, image 1 de 1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 8, image 1 de 1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 9, image 1 de 1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 10, image 1 de 1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 11, image 1 de 2 Disassembling Fujifilm Endeavor 100ix Outer Casing: étape 11, image 2 de 2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Eric Nicolai
Membre depuis le 01/10/11
679 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-5, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 1,331
