Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling GN Resound Hearing Accessory Multi Mic
Ce dont vous avez besoin
    1. Disassembling GN Resound Hearing Accessory Multi Mic, Opening the case: étape 1, image 1 de 1
      • A second used Multi Mic was purchased as a back-up but is was discovered that the mounting clip was loose and finally fell off. The seam between the front cover and back had a slight gap and appeared to be the means of separation. DO NOT DO THAT! The previous owner did and broke the attachment posts inside the case.
      Demander à FixBot
      Ajouter un commentaire
    2. Disassembling GN Resound Hearing Accessory Multi Mic, Opening the Case: étape 2, image 1 de 1
      • The clip is held with one T6 machine screw that threads into an interior, rotating backplate. The screw access is hidden by the metal (logo) cover plate attached to the clip. The screw cannot be removed or tightened easily because of the rotating backplate, so Multi Mic case must be opened.
      • The front and back are actually held together with three T6 TORX screws, hidden by rubber plugs (Blue) that can removed with a toothpick or the ifixit tweezers. Once the screws are removed (a small magnet is helpful) the two halves can be carefully taken apart.
      Demander à FixBot
    3. Disassembling GN Resound Hearing Accessory Multi Mic, Separate and detach battery: étape 3, image 1 de 1
      • Insert wisdom here.
      Demander à FixBot
2 autres ont terminé cette réparation.
Jeffry Long
Membre depuis le 03/18/22
151 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 47
Total : 999
