Aller au contenu principal
Disassembling Garmin Nuvi 1200 Logic Board
Ce dont vous avez besoin
  1. Disassembling Garmin Nuvi 1200 Logic Board, Logic Board: étape 1, image 1 de 1
    • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
  2. Disassembling Garmin Nuvi 1200 Logic Board: étape 2, image 1 de 1
    • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
  3. Disassembling Garmin Nuvi 1200 Logic Board: étape 3, image 1 de 2 Disassembling Garmin Nuvi 1200 Logic Board: étape 3, image 2 de 2
    • Lift cover off of unit.
    • Be careful not to lose small rubber piece on the bottom right corner.
  4. Disassembling Garmin Nuvi 1200 Logic Board: étape 4, image 1 de 1
    • Disconnect ribbon cable from logic board.
  5. Disassembling Garmin Nuvi 1200 Logic Board: étape 5, image 1 de 1
    • Remove two T5 torx screws holding down logic board.
    • Disconnect battery.
  6. Disassembling Garmin Nuvi 1200 Logic Board: étape 6, image 1 de 1
    • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
6 autres ont terminé cette réparation.
Zachary Landau
Membre depuis le 11/28/10
206 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 5,241
