Aller au contenu principal
Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case
Ce dont vous avez besoin
  1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: étape 1, image 1 de 1
    • Unplug the toaster from the electrical outlet.
  2. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: étape 2, image 1 de 2 Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: étape 2, image 2 de 2
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: étape 3, image 1 de 1
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
Ron Gajdos
Membre depuis le 10/16/13
307 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 Membre de l'équipe UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 1,134
