Introduction
The central button is responsible for the stopping and playing of audio tracks. The side panels must be removed before the button can be removed appropriately.
Pièces
Aucune pièce nécessaire.
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  2. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  4. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  5. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
  6. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
    • The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
Membre depuis le 09/03/2012
101 Réputation
9 tutoriels rédigés
Équipe
Clemson, Team 15-3, Benson Spring 2012 Membre de l'équipe Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 957
