Aller au contenu principal
Disassembling HP Pavilion g7-2275dx Front Panel
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Disassembling HP Pavilion g7-2275dx Front Panel, Front Panel: étape 1, image 1 de 1
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  2. Disassembling HP Pavilion g7-2275dx Front Panel: étape 2, image 1 de 3 Disassembling HP Pavilion g7-2275dx Front Panel: étape 2, image 2 de 3 Disassembling HP Pavilion g7-2275dx Front Panel: étape 2, image 3 de 3
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
  3. Disassembling HP Pavilion g7-2275dx Front Panel: étape 3, image 1 de 2 Disassembling HP Pavilion g7-2275dx Front Panel: étape 3, image 2 de 2
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  4. Disassembling HP Pavilion g7-2275dx Front Panel: étape 4, image 1 de 1
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  5. Disassembling HP Pavilion g7-2275dx Front Panel: étape 5, image 1 de 2 Disassembling HP Pavilion g7-2275dx Front Panel: étape 5, image 2 de 2
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
Erik Miller
Membre depuis le 04/22/14
2 141 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-51, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 membres
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 56
