Introduction
The feed roller assembly is a critical component responsible for smoothly feeding paper through the printer. Over time, these rollers may wear out or accumulate debris, leading to paper jams and print quality issues. Whether you're troubleshooting an issue with paper feeding or looking to replace a worn-out roller, this step-by-step walkthrough will help you navigate the disassembly process with a Photosmart c3180 printer.
Ce dont vous avez besoin
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Set aside the ink cartridge carriage.
Remove the three T10 12mm Torx screws holding the paper guide to the printer body.
Lift the paper guide directly up to remove it and set it aside.
20 autres ont terminé cette réparation.
7 commentaires
m ayuda este tipo d informacion muchas gracias saludos n-n
The HP Photosmart c4580 has enough in common with this model that this guide enabled me to get into the head cleaner reservoir and remove the years of accumulated ink gumming up the works - thanks!
